Hi everyone,
I would like to clarify how discount rates are currently handled across scenarios in OSeMOSYS.
If I am not wrong, it is not possible to change the discount rates—neither globally (DiscountRate) nor technology-specifically (DiscountRateTech)—as dynamic parameters within scenarios in standard setups.
To assess the impact of different discount rates on the results, my understanding is that the proper way is to create separate cases/model rather than using a scenario switch within a single model run.
Could someone confirm if this understanding is correct? Additionally, is there any plan to allow discount rates to be defined dynamically by scenario in future releases, or is generating separate case intended to remain the standard approach?
Thanks for your insights!
Best
