Overview
This posting covers the open licensing of teaching materials and of documents and content more generally.
Normally a Creative Commons CC‑BY‑4.0 attribution license should be used unless other considerations apply. This license allows others to share and adapt and also include the content in commercial products. The only requirement is that all previous contributors be acknowledged (the “BY” qualifier). The share‑alike variant is the Creative Commons CC‑BY‑SA‑4.0 license (additionally the “SA” qualifier) that essentially means the same license must be retained in the case of the original work or reapplied in the case of derivative works.
The CC‑BY‑4.0 license is also generally recommended for data, so that any data or other numerical information embedded in a document can extracted and used under suitable terms too.
Creative Commons CC-BY-4.0 specifics
The following information relates directly to the Creative Commons CC‑BY‑4.0 license.
Technical
A license notice can be added to the “printed” material as follows:
That same information can often be added as file metadata (using the PDF and XMP protocols) by filling in the document properties. Alternatively, that information can be written in manually using the command‑line ExifTool utility.
Legal
Specifically, Creative Commons advise that you are free to:
Use case | Permissions |
Share | copy and redistribute the material in any medium or format |
Adapt | remix, transform, and build upon the material for any purpose, even commercially |
Under to following terms:
Term | Explanation |
Attribution | You must give appropriate credit, provide a link to the license, and indicate if changes were made. You may do so in any reasonable manner, but not in any way that suggests the licensor endorses you or your use |
No additional restrictions | You may not apply legal terms or technological measures that legally restrict others from doing anything the license permits |
And with the following notices:
Notice |
You do not have to comply with the license for elements of the material in the public domain or where your use is permitted by an applicable exception or limitation |
No warranties are given. The license may not give you all of the permissions necessary for your intended use. For example, other rights such as publicity, privacy, or moral rights may limit how you use the material. |
It is important to apply version 4.0 and not some earlier version. Version 4.0 was the first release to deal properly with intellectual property law in relation to data and databases. Version 4.0 is also international and does not require dedicated ports for different legal jurisdictions.
Useful links
- Creative Commons organization: landing page
- Creative Commons organization: download artwork for license buttons
- Creative Commons organization: XMP metadata for CC‑BY‑4.0
- Wikipedia: Creative Commons licenses
- SPDX project: list of common license identifiers and texts
