creating new model
I created a new model with different name and tried running in Osemosys cloud but I can not visualize the result. But, if I edit the already loaded workshop model from exercise in CLEWs, i am able to visualize the result. What should I do to visulaize the result?
How can I create my own model in MoManI and run in Osemosys cloud with visualization?
For instance I tried building the simple RES as below
Then when I run, there is no visualization
How should i move forward to build my own model from MoManI and Osemosys cloud?
Regards,
Hemanta
Dear Hemanta,
The osemosys-cloud is designed for a specific naming convention and it will not work if you use a different one. If you wish to visualise results from models with different naming convention, I’d suggest you run the model directly in MoManI and view the results there, or you may also run the model without an interface and extract the results from excel. There are instructions for all these steps on: http://www.osemosys.org/
Dear Franscesco,
Thank you. It helped.
I was able to run the model but later when I added the water balance for the model, the osemosys failed to visualize however the GLPK solver shows the model has primary feasible solution.
What might be the cause of that?
Regards,
Hemanta
