Hands-on 5 (UI): OSeHO5 case not appearing after model run
I am currently completing Hands-on 5 (UI) of the updated OSeMOSYS course.
On page 7, after running the model and filtering the cases, I am instructed to untick the unwanted case and select OSeHO5. However, I still only see OSeHO3, and the OSeHO5 case does not appear, even after running the model.
Could you please advise on how to refresh or correctly load the new case so that OSeHO5 becomes visible?
Thank you very much for your support.
Dear Sufyan, please double-check that you have created a new case named OSeHO5, rather than updating the previous case (OSeHO3). If you continue to experience the same issue after doing this, you can share a screenshot of the Run tab for further review.
