The commodities maize and crops is measured in Mt but the app gives the unit PJ how do i change it pls and will it affect the results if it is not changed ?
Hi Blessing,
You can change the units on the interface - on commodities (for example) you can select the unit to the right of the commodity name using the little drop down options available.
It will not affect the results, as the units on the interface are important for running the model within the interface, whereas you are doing it on the cloud. Just make sure you are adding the correct data values from the OU course and you should get the correct results!
Kane
Is Mt the same as MTon?
Hi,
Yes!
Best
