Shareholder's Return
The section for approximate average return, what value to use and what it means
Hi Emma,
Thanks for your query.
Entering an approximate average return is required only to initiate calculations of the Internal Rate of Return (IRR). It is recommended to enter 10 as the starting value for the IRR calculations.
More information can also be found in the FINPLAN Manual.
I hope this helps!
Naomi
Yes it does!
Thank you very much Naomi
