Error message when running my model(Hands on 3 - 5)
Subject: Request for Assistance with Clews Modelling Course
Dear all,
I recently began the Clews modelling course, and initially, I was quite excited as I successfully followed the hands-on exercises. However, I’m now feeling a bit lost and would appreciate some help. I have attached my results so far for your review, and I would be grateful for any guidance you can provide. My software version is 4.3
Thank you in advance for your assistance.
Oluwaseyi
Links - Model
https://www.osemosys-cloud.com/rails/active_storage/blobs/redirect/eyJfcmFpbHMiOnsibWVzc2FnZSI6IkJBaHBBN3dsQnc9PSIsImV4cCI6bnVsbCwicHVyIjoiYmxvYl9pZCJ9fQ==--1e43bb956bad1797b700e4d69adfce1bf708efe9/model%202.0.txt?disposition=attachment
Data
https://www.osemosys-cloud.com/rails/active_storage/blobs/redirect/eyJfcmFpbHMiOnsibWVzc2FnZSI6IkJBaHBBNzBsQnc9PSIsImV4cCI6bnVsbCwicHVyIjoiYmxvYl9pZCJ9fQ==--edcc0ad9c9038c8bcaefe868c2126ec4dc7fc414/Renewed%20data?disposition=attachment
All links are for hands-on 3
Hi Oluwaseyi,
I was able to take a quick glance and noticed that your values for InputActivityRatio are all set to 0. Also SpecifiedDemandProfile is 0 and YearSplit is 1. Please check these!
Best, Kane.
Thank you for looking into the mistake I made.
I have corrected the error and saved it.
The major issue I had then was that I didn’t save my data.
This is the hands-on 3 task, and nothing was said about SpecifiedDemindProfile; this is why it had 0 input.
The user can introduce two types of demand in OSeMOSYS:
• AccumulatedAnnualDemand: it must be balanced by the supply on an annual basis
• SpecifiedAnnualDemand: it must be met based on a “time-of-use” profile, such as daily fluctuations in electricity demand.
You will learn more about the difference between them in the following labs. For now, you will introduce values only for the AccumulatedAnnualDemand. In this way, you will define a value of demand for each year of the time domain. The supply chain needs to meet this demand over the year.
For the year split, it is expected to be 1.
Find the attached image.
The model didn’t run after making the changes I could make
