Hi Francesco,
I accidentally deleted the email thread. Please find attached the text file for handson5 and the results I obtained. I’m looking forward to your guidance.
Israel.B
Dash-handson 5 result.pdf (102 KB)
data_handson 5 activity 5 (13.9 KB)
Hi Israel,
I can see that YearSplit is not entered: in the file that you shared, it is 1 in all the timeslices. That may be the reason. Check it and let us know.
I can also see a couple of parameters that I do not remember to be in the material (but I may be missing some latest updates): you have a few GW of residual capacity for coal and gas from the second year on; that seems not correct; you also have a very high value for the emission activity ratio: which units are you using? is it a parameter added in hands on 3 or 5?
Dear Francesco,
Many thanks for your support. As you said, the mistake was with the year split input. I should have removed the scenario data as my earlier input on the year split was as the picture attached to this email.
Regarding the other inputs, I have not changed the default settings since installing Osomosys. On the emission activity ratio, the unit was set to Mton/PJ.
Thank you.
Israel Biramo
