Hands on lecture 5
Dear Francesco,
Please, my year split is showing only one row, i.e; S11 only.
How do i get the four year split i.e; SD, SN, WD & WN to enable me move further.
Thanks
Paraclete
Dear Paraclete,
It looks like there may be only one time slice defined in your model. You can first define the time slices (SD, SN, WD and WN) and then you should be able to see them all when you insert time-dependent parameters. Please feel free to join the troubleshooting session for the summer school on Wednesday at 13 CEST, registering through this link: https://zoom.us/meeting/register/tJIlceyoqjopHdPQNMsVOphG-HxTKrF-oidR
We shall help you through this if you are unsure how to proceed.
Hi Francesco,
I had the same issue. I tried defining the time slice by configuring the model by changing number of seasons and day types. I was able to change the all values in other parameters asked in the exercise but results of running the model failed… I am not sure why. I send the snapshot of years split data table. Is this ok timeslice?
Thanks in advance,
Thaysa
A segunda-feira, 25 de abril de 2022 à(s) 08:26:27 UTC+3, fr.ga...@gmail.com escreveu:
Dear Paraclete,
Are you still having problems?
Best
Leigh
Dear Thaysa,
That Time splice looks correct - are you still having issues with the model ?
the specified demand profle should look like this:
Dear Thaysa and Paraclete,
Please adjust the season count to 2 and the daytypes to 2 on the main ‘home page’ for your model. This should solve the issue.
Best
Leigh
Dear all,
Thanks for pointing out. Your rightful concerns were caused by unclarity in the course material published on OpenLearn Create. In particular, some misleading instruction in Hands on lecture 1. Apologies for this. Now the updated instructions are online and no one should incur in the same problem. In the meantime, you may follow what Leigh suggested above.
The way to change the number of time slices is from ‘Configure Model’, on the top right part of the screen. You may add 2 as the number of seasons and 2 as the number of day types.
Kindly revert if this seems unclear.
Thanks Francesco and Leigh. I have corrected it.
Regards
