Hi,
I am finding it difficult trying to understand how to input the details on activity 1 of hands on7, the inputs I need to make are not very clear to me, kindly assist.
Thank you.
In Activity 1 of Hands on 7 you need to put lower limits for built up land and water bodies. These limits need to be put as ‘lower limits BY MODE’. The technology whose modes 6 and 7 represent built up land and water bodies, respectively, is LNDAGR001. So, the limits must be put for that technology.
Putting them on the upstream land technologies LNDBLT and LNDWAT does not work, because those technologies only operate in mode 1.
Ah, ok, I see, this is noted.
Thank you Francesco.
Please how long does it take to run, am on activity3 of hands on7, its taking longer time in running, is that ok? or I can cancel it?
It should always take around the same time to run the exercises, i.e. a few seconds. If it takes longer, it probably means that there is a mistake in the inputs that prevents the solver from finding a solution. Please do check your inputs in the last step carefully.
