I am having an issue with Question 2 in the Hands-on 11 quiz.
I ran the model using MUIO v5.6. In the Use by Technology by Mode results, the industrial LPG boiler DEMINDLHELPG does not appear, which indicates that its LPG consumption is zero. This also seems consistent with the Hands-on 11 document, which states that only DEMINDLHENGS is active and that the LPG boiler residual capacity is not used.
However, I have tried entering 0 and 0.00, but both were marked incorrect. I also checked the other visible values:
DEMINDLHENGS shows natural gas consumption, not LPG.
DEMRESCKNLPG refers to residential LPG cooking, not the industrial boiler.
Could someone please confirm the expected answer or check whether there may still be an issue with the wording or answer key for Question 2?
Dear @winwul, I believe there is an issue with the configuration of the question. I have requested that the quiz be updated to match the latest version. I will keep you posted once the platform has been updated. My apologies for the inconvenience.
Stumbled upon the same number but slightly different problem. Here I inserted 48.75 for the value but marked as wrong (have tried 41.25 too, but still marked as wrong answer). For reference, this is the result that I got (pic 2). Thank you in advance for the assistance and support.
